bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
The pin is missing but it doesn’t discharge unless the lever is depressed. it is a 2.5 lbs extinguisher and the top sticks out.That has to be an experience - having the FE go off without knowing it!
That bags seems to have it covered up pretty well - how the heck does it pull the pin in the bag?
Excellent mounting idea.Put mine on the tabs on the back of the seat.
(seat is facing rear for BH use)
I have an aluminum head replacement, just haven't been where the tractor is to change it out.
Besides, a plastic head extingisher is better than no extinguisher.
[/QUOT
"A plastic head extinguisher is better than no extinguisher"....... until it isn't ...... and you are left holding a broken plastic handle in your hand.
..........While the fire rages on.
Nope, swap out the whole thing.You can change plastic valve to aluminum type..... without discharging extinguisher?
Lol. End of times. We just had a two page thread on mounting a cane to an FEL. A hole in the FEL was determined to either be de minimus or nearly reducing the tractor to scrap.Flint
you drilled two holes into the loader arm ?
It’s worse than that. I’ve ordered the same mount for myself. Probably mount it the same place and way (thanks @Flintknapper, lots of good ideas to plagiarize here, and some to stay away from). Anyone want a nearly totaled tractor in a month or so?Lol. End of times. We just had a two page thread on mounting a cane to an FEL. A hole in the FEL was determined to either be de minimus or nearly reducing the tractor to scrap.
No.Flint
Danger......!No.
The loader 'Mount'. Its HUGE and very thick.
So, yes.....I drilled and tapped (2) 1/4"-20 holes in the FEL 'Mount' and bolted it on there.
Well the mount showed up today, so give me a bit and I’ll see what can be done. I did burn up a pickup down at the barn about 15 yrs ago. And I was worried for the tractor.Top up the insurance and hope that if it does catch fire it's outside and away from the barn...
