Looking for any suggestions. Turn key dash lights come on no start. Did some testing to with test light and voltmeter. With Ignition switch in run position no power to black white wire starter. Disconnected ignition switch and bypassed got 13.4 volts at starter but starter did not engage. Replaced starter and ignition switch same result. Replaced ground from battery. Replaced timer relay. Checked safety switches in the chain, power was flowing though them all from what i could tell. running a wire from the battery directly to the starter contact resulted in clicking the gear in to place so that’s something. Had battery tested they said it was good. So for some reason power doesn’t get through the ignition switch. is There a safety switch attached to the brake? I couldn’t find one but I know the brake has to be engaged to start. I found 2 under the seat 2 underneath right and one underneath left but none seem to be tied to the brake so don’t know if that is it? This Thing has me at a loss.
