L 2501 forward front axle support leaking
patenaud
Kubota L2501
Apr 22, 2021
Ottawa
Hi.
I was doing my 100 hour maintenance. When putting grease into the forward front axle support some grease is leaking out of the bottom. I did manage to get it coming out of the breather plug but there is a lot coming out of the bottom at the same time. Does anyone know if it's simply a matter of taking of the axle support and getting a new seal for it? A guess a better question would be, is there a seal there? I did notice that the bolt on the front with the lock washer was loose. I thought that might be it so I tightened it, tried again but the grease still flows ouf of the bottom.
Thank you.
Denis
GrizBota
Apr 26, 2023
1,147
733
Oregon
The pivot bolt should have a lock nut on it and tightened as per the service manual (essentially snug, loosen that lock nut, tighten the bolt and then the lock nut). The front zerk (here we go again) has a vent and seal as you mention. IIRC, the rear zerk does not and too much grease basically fills the driveshaft tube surround with grease. Maybe that’s the source of the extra grease?
patenaud
Kubota L2501
Apr 22, 2021
Ottawa
Thanks for the reply. I did tighten the bolt and lock nut but not with a torque wrench. I'll try that this weekend. If that doesn't work then I assume the seal is bad and I'll have to replace it or get some gasket "maker" and plug it up for the time being and keeping an eye on it.
11,083
No seal just a simple O-ring seal, 04816-00490.
It's not a tight system, so a little grease coming out isn't that abnormal.
The front bolt is a lash adjustment do not tighten it too much!
patenaud
Kubota L2501
Apr 22, 2021
Ottawa
Thank you. What I might do in the meantime is apply a small amount of gasket sealer from the outside to hopefully prevent anything from getting in there.
Denis
11,083
Denis
It's really not going to do much if anything.
The grease keeps moisture out.
