On the BX tractors, there is only one wheel that fits both sides. You can't reverse the wheel onto the axle because there is a depression (chamfer) for the wheel nuts, just like on a car.
I'm sure that I'm not the first to think of it.On the BX tractors, there is only one wheel that fits both sides. You can't reverse the wheel onto the axle because there is a depression (chamfer) for the wheel nuts, just like on a car.
Yep and if the rear tire goes flat well you better watch you dont rip the side wall off! Also cant turn the gage wheels so I can roll the deck out from underneath. I would love to have at least 2" spacers and 3" wouild be better!With the 54" - 1.5" is max - otherwise the rear tires will rub! 2" will work fine on a 60" mmm.
First vid, Ive seen it before, is only 1 1/2" spacers, I would love 3". Second vid no MMM! The OP has turf tires which gives more clearance. Again on my machine BX23S 54" deck R4 tires with the deck raised I can not turn the left rear gage wheel so my crippled self can easily roll the MMM out from under the tractor. It will turn if I drop the MMM almost to the ground. Spacers will only make that worse. Like I said if the left rear goes flat while mowing either the tire side wall (VERY THIN) gets torn up or that gage wheel. Maybe both? If I cant go big I will do without.
That's what I have on mine, but I've not noticed any difference at all.The 1-1/4" work nicely with the 54" deck/R14s. I noticed a considerable difference when in the seat.
Thanks for your honesty!That's what I have on mine, but I've not noticed any difference at all.
I am wondering how one would notice if there was a difference or not?Thanks for your honesty!
Not many will admit that something they bought didnt really make a difference. Thats why if I cant have 3" I will do without! I only have one steep spot where spacers would be nice but I continue to cut it vertically!
Sorry for the question, but I am really curious.I have placed spacers on two BX tractors - the first time was on my brand new one and the difference was very noticeable, that was with 2". The second was only 1.5 per side and it too was noticed easily.
What criteria did you use to determine the difference was noticed easily?
I added 1.25" spacers on mine. Prior to doing so I placed a chunk of 4x6 under one wheel then pushed on the ROP bar. Once the spacers were added, I did the same. Based on that I noticed more force was needed for the same result.Sorry for the question, but I am really curious.
Just sayin'... whenever I make a repair to anything is seems to me that things improve greatly...even changing oil in the vehicles...they seem to run better.
Some LOL here but also some truth...Again, just curious, because I am not sure how I would evaluate the change...even though with 4 foam filled tires on my BX and wheel spacers on the rear, I truly believe it is MUCH more stable. BUT I have no way to quantify it.
Edit: I did see a you-tube video where a guy added spacers, and did a before and after test on the same slope, where he tried to life the tractor on it's side by pushing on the ROPS. Before it seemed he could lift a rear wheel easily, afterwards he could not...They were not thick spacers, I think 2" or less...if I remember correctly.
Yup, hills in the woods where I have to avoid rocks, trees, fallen trees, etc., and there are holes and depressions in the ground.My BX23S has a 700# BH on the back, and the tractor isn't 'stressed out' carrying it.
Providing the chipper is properly secured to the 3PH ( ie..doesn't sway..) ,no real reason to put any spacers on, unless you're driving diagonally on steep hills ?
