Zg222 15A “main system” keeps blowing
Helicoppter
Zg222
Sep 21, 2023
MS
Recently tried to jump off my zg222 with my golf cart but had the battery cables hooked backwards. Now the 15A main system fuse blows the moment I turn the ignition to “on”. All other fuses are in tact, and I can’t find a short in any of the wires. I’m at a loss
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
Have you tried unhooking battery for a while?
jaxs
B1750HST
Jun 22, 2023
735
522
I'm afeared you done gone and cooked the alternator or melted insulation off a wire. Examine wires for burnt insulation and if non is found unhook wires from alternator to see if fuse no longer blows. If that doesn't work post back so we can help you dig deeper.
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
I would start with tracing wires in the rectifier circuit, and/or. The rectifier itself. This is what actually does the charging. Good chance you melted wiring going to it or the rectifier. It should be under the top engine cover, runs off the top of the crank shaft.
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
Sorry wrong terminology. Look for stator circuit.
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
How long was battery hooked up backwards?
If you check voltage in the battery is it showing pos or neg. There is a chance your battery has been reversed polarity. Try another battery.
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
Did you get it yet?
