Yellow Dipstick
Stmar
B2650HSDC
May 23, 2017
938
54
Buffalo, Wyoming
Polaris and Kubota must have gotten a good deal on Yellow plastic, they both use it for Dipsticks. I saw a YT vid where the guy used a black marker (Permanent/Magic) to paint the dipstick so that it would be easier to see. He got the suggestion from an experienced mechanic but he said he did not know if it would come off or react with the fluids. Has anyone used this method? Not really a big deal but interesting how people deal with issues.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,440
1,733
Kalamazoo, MI
I find it hard to believe that a microns-thin coating of ink on a dipstick could cause any adverse effects on your oil or engine.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
Kubota painted the oil dipstick on my L3301 the same black/gray body color, also it looks like they tried to hide it.
rr
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
With the glossy plastic, I don't know if the color matters. It's hard to see. I don't think using a Sharpie or similar would harm anything or make it easier to see.
Paint is probably just as harmful or harmless as a Sharpie, but paint chips in a bearing can't be good.
mcfarmall
Sep 11, 2013
1,440
1,733
Kalamazoo, MI
Sump to pump to filter to bearings correct? Kubota OEM filter should trap paint chips.
jkrubi12
Sep 24, 2012
403
299
right coast
If you do color it or paint it, only try one side for now, see if it helps; It may help you see the oil on the still-yellow side better.
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
117
67
SW Michigan
I used a black Sharpie on 1/3 of each dipstick. It provides enough contrast to see the oil level.
jaxs
B1750HST
Jun 22, 2023
984
760
I could see why oil in gasoline engines might be difficult to see on yellow background but since oil quickly turns black in diesels yellow makes oil easy to see. I've relied on reflected light for over 60 years so dipstick color isn't high on my list. :unsure:
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
I had the same problem with not being able to see the fluid on the yellow stick. Another member on this site recommended scuffing the end of the dipstick with sandpaper. Problem solved. Did it to both the transmission and front axle dipsticks.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
A simple spring steel dipstick works. It has since we neeeded dipsticks to check oil levels in machines.
Manufacturers are finding ways to save money, and producing a more difficult and deficient product for the consumer.
jaxs
B1750HST
Jun 22, 2023
984
760
They evidently listen to their artificial intelligence rather than customers about these things.
:cautious:
PaulL
2,638
1,615
NZ
Why use artificial intelligence to give you bad advice when you can get perfectly bad advice from the average human intelligence far more cheaply?
BAP
Dec 31, 2012
3,048
1,164
You can blue the metal end of a dipstick with a torch...
Not the plastic hydraulic oil dipstick which is yellow and probably the one that the OP is referring to.
PaulL
2,638
1,615
NZ
Sure you can. It'll go very blue. It just won't be useful as a dipstick afterwards.
5,157
Drill a 1/16" hole at the full mark on the plastic dipstick. If the oil fills the hole, it has enough oil in the system. If not, add oil til it does.
