Video of problem:
B2650. Just had it serviced at Kubota a couple weeks ago. Put about 15 hours moving dirt around and doing some grading. Tractor has worked flawlessly. No issues whatsoever. Went to park it to switch out the front bucket and then went to restart it and nothing. Battery works and dash lights up, but no turnover or crank. I've checked the fuses and they are all in-tact. I'm thinking it's a safety switch. Any thoughts on what else it could be? My HST Pedal switch went out a few years ago but the symptoms were a little different (blown fuses).
Couple questions:
1. If it is a safety switch is there an easy way to find out which one without replacing each one by process of elimination?
2. If it isn't a safety switch what other areas should I look for?
3. Is bad OPC a possibility??
Thank you in advance for the help.
Couple questions:
