RC60-82H mower deck spindle feather key removal
plumber mechanic
Kubota B8200 with rc60-82h mower deck, Kubota L2550D
Sep 18, 2023
53
I need to replace bearings on the right spindle. I have the top nut, lock washer and regular washer removed but the pulley will not lift out as it is held in by a feather key. How do you remove this feather key?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,431
1,719
Kalamazoo, MI
In my line of work, bigger keys are drilled and tapped (prior to installation) and are removed using a bolt as a jack screw. Smaller ones are removed with a pair of side cutters.
I had to Google what a feather key was...never heard them called that in 35 years of machine repair.
FYI for the rest of the inquiring minds, a feather key is a square key with rounded ends that fits in a keyway machined into a shaft with an end mill ( a pocket ).
MOOTS
MX6000
Jun 27, 2019
2,179
2,698
Canton, Georgia
Parts breakdown shows the spindle shaft coming out the bottom. Have you tried a puller on the pulley to remove from the shaft?
plumber mechanic
Sep 18, 2023
53
Thanks for your response. The pulley will lift off the spindle but the feather key keeps holding it in place. The feather key is entered into the spindle and recessed into the pulley with only the very top exposed. Can't get on it with a side cutter or pry it out with a thin screwdriver. Any other suggestions? Attached below is a photo.
MOOTS
MX6000
Jun 27, 2019
2,179
2,698
Canton, Georgia
The pulley will come completely off of the spindle?
Remove grease fitting and get a puller on that pulley. Key should slide off of shaft. Probably has a microscopic speck of rust holding it together.
