Kubota LA481 Loader....I cannot find the replacement parts for it
debbieloveskenneth@gmail.
Kubota L3300 with LA481 Loader
Sep 18, 2023
61
Little Rock, Arkansas
The middle valve of this is leaking oil. The plastic rings were replaced on it and it's still leaking. A man here in Arkansas wants around $500 labor to fix it after I purchase the rebuilt kit. I can't find the rebuilt kit...he is saying it's too old for them to make anymore. He pointed out an entire value to purchase but it was over $1100. That would put me at $1700-1800 with labor and tax on the part. Can anyone direct me to a website with a rebuild kit for this valve?
6,624
The rebuild kit probably only includes "O" rings. Everything else in a valve like that is precise machined and nothing to fix. You can probably get all the "O" rings at a hydraulic repair shop at very little cost.
Sep 18, 2023
61
Like I was saying, the plastic rings were replaced and it still leaks. I called Kubota today and they gave me this below. The kit is still made for the rebuilt kit but it's called a detent kit. I am about to order it. Thanks for the help.
De Tent Kit: $155.69
Part #75536-65400
5,243
Part #75536-65400
The detent kit goes on the back of the valve. It isn't going to fix a leak anywhere else. $500 labor to install seals is insane.
Post a picture showing the entire valve and how it's mounted. Plenty of valves that could potentially work and for a lot less than $1500.
3,242
1,853
Messick's shows the seal parts in stock. You can probably get them from your dealer. I'm assuming it's leaking around the spool stem?
5,243
Is that the valve cost or labor cost or both? Can you send me a link to the valve?
You can install the valve yourself. Disconnect the 7 hoses and unbolt the old one along with the joystick. Put them aside. Bolt the new valve on - you might have to drill two new holes in the plate. Hook up the hoses - you are done.
There are lots of valves you could use. This is just one.
5,243
Thank you so much....this is a much cheaper fix.
I just checked the hydraulic flow on your tractor - you would need the 21 GPM version of that valve. Its just a little more expensive amd don't forget to order the power beyond sleeve.
Edit: Crap - I just noticed the 21 GPM valve is not available with float. KTime to do a little more looking
5,243
Heres a 25 GPM valve:
Sep 18, 2023
61
So any idea where to look at?
