Does anyone know where the Electric Control Unit is on my 2004 Grand L5030? I have a starting problem and my diesel mechanic wants to check for any codes. The tractor will not turn over. When you try to start it nothing happens. No click, no nothing. Everything else works as they should such as lights, fan, radio, dash lights... This happened late last winter but both of us have been to busy to check for the cause. He "thinks" it might be the main safely switch on the foot pedal. Of course this happened with 16" of new snow on the ground. So to keep my driveway and my customers driveways opened we hot wired it. He also had to cut a little bit of shaft off on the fuel soleniod. Now to start it I touch a wire from the starter to a bolt head and to turn it off I pull on a wire that is connected to the manual fuel shutoff lever on the fuel solenoid. We are hoping by looking at any codes it might give us a hint what the problem is.
