martinlaurentide
Kubota: BX2200, BX2750D, LA211, box; Woods: BH6000, Post Hole Digger-might sell
Update. Tank off showing how to avoid emptying but no idea from where it's leaking and would need to feed fuel somehow to see but stopping for the night. 5 last pictures. attached...
UPDATE: relating to last photo with blue dye in hydraulic fluid showing where the leak is emanating from... I need to figure out how to remove the fuel tank. Wondering if I need to empty it or if it can be loosened and move enough to address the leak or at least determine the source if / what parts are needed... I had already emptied it a week back to clear some blockage etc... and refilled it to do a job...
2001 bx2200 hydraulic leak @ rear right side per video clip, above the filter, when running. Ideas welcome... Thanks.
Been looking online and in the shop manual to find process but as stated to start from top, it means remove seat, metal behind floor for acces to inspect?
Seat and floor are off... need to find how to remove the fuel tank.
Suspicion from the start looking more and more likely: is that the inaccessible bolt that holds the HST in place (top right looking forward) was loose and loosened more but per pics, still cannot get to it.
Any hints as to where the fuel tank fastenings are... checking manual for that but I find it hard to find much in there...
