2011 L3400 DT
Billfishin
l3400, BX23, RTV
Jan 9, 2022
All, My l3400 will start and run under load for roughly 15min. After that time the engine starts to drop RPM. I have changed the fuel filter several time and chacked the flow from the tank. took a long shot and changed the air filter today and ran with the fuel cap loose. The RPMs will drop until i take the load off of the PTO then i can get RPM for a min or two. Any help would be much appreciated.
10,697
Have you checked fuel flow at the injection pump input?
A bad lift pump, clogged inlet or outlet of the filter housing will both do what your stating.
