Kubota F3680
Th02msn
Kubota F3680
Sep 12, 2023
Aberdeenshire
Hi all
I ordered a full service kit online specifically for my F3680 and there are 2 filters that Im just not quite sure of…
They are almost identical to the 2 fuel filters but only half as large again?!
Can anyone help with their location?
5,553
Think you got the wrong filters.
You're across the Pond? I looked up parts @ Kubota Tractor Corporation - Illustrated Parts List (kubotausa.com)
I think there's a similar parts look up for Europe. If you're smarter than me, you can adjust your VPN accordingly to access USA site?!?
I see 12581-43012. There's 2. One is between tank and electric lift pump and second should be near the injection pump.
Here's a screenshot with part number. Both are the same #.
That's the same part # as my BX2360. I'll try to get a photo with measurement reference.
Looks about 4” long and cap is about 2”.
a
MOOTS
MX6000
Jun 27, 2019
1,965
2,277
Canton, Georgia
Those will work. They are just fuel filters. One is located on right side of radiator support. Other is under floor pan just behind the front tire on same side.
I can take pictures tomorrow if you need them. I have a F3680 in the shop at work.
MOOTS
MX6000
Jun 27, 2019
1,965
2,277
Canton, Georgia
a View attachment 111436
He got the right ones. For whatever reason the F’s used a larger filter. I’ve been getting bulk of the part # you have and running them in our 4 F mowers with no problems, other than the clamp doesn’t clamp them.
5,553
Thanks Matt - OP is Scotland if I recall correctly. Not sure if that makes a difference.
Kubota USA part showed same as mine, but I know you deal with the F series more than anyone I can think of here on OTT.
Sounds like he’s in good shape with what he’s got.
MOOTS
MX6000
Jun 27, 2019
1,965
2,277
Canton, Georgia
@Th02msn here are the filter locations. The one under the floor pan should be clamped to that little bar poking up to the left of the filter. Don’t mind the ratchet strap… axle fell out of this one today.
