Well, the picture helps, somewhat. The AC compressor, according to the diagram, should be fed from a 3.0 metric Red with White stripe conductor. The conductor comes a 6-pin connector attached to the main engine harness. The conductor occupies pin 4. On the mating connector the conductor goes to slow blow fuse box 2-3, from a 40A fuse. The conductor remains a 3.0 metric R/W.
One question is which is the hot conductor and which is the dud feeding the fuse box. I would suggest looking at that with an ammeter to see which one has current flowing.
On the left hand side of the diagram, looking at the fuse box, there are 5 feeders going into the fuse box supplying power. It is hard for me to see the stripes to see if all feeders are going to the fuse box. So I have to find out why the red wire with white tracer doesn't have power.
Of course the other question is why the jumper to begin with. Did a conductor get damaged? Did a conductor pull out of its crimp, and not understanding how to release the crimp, a jumper was kludged in?
A matter of elimination by matching the physical wiring to the diagram and recording discrepancies.
Good luck.
