L345DT headlight bulb change
Grady 580
L345DT
Sep 3, 2023
11
NH
Can anyone help me with changing a headlight bulb on this machine? I feel pretty stupid but short of unbolting the whole assembly I can't figure it out. the center is spring loaded but nothing will turn and I didn't want to break something. I guess it's so simple that the manual doesn't mention it.
3,051
Deleted duplicate post
3,051
Here is a picture of the bulb from my L185. It may be the same one that you have on the L345 (or not)
I recall that the glass bulb is too large to fit through the rear of the assembly and the glass lens has to be removed. I vaguely remember that just the glass comes loose and the metal part will not pry apart, just the glass. But I know it will be a lot easier to get the whole assembly off the tractor before you get to frustrated. Then look at the back side and see if you can determine how the bulb is held in place. From looking at the bulb it has to rotate CCW to be removed (looking into the assembly glass)
I know I have pictures but can’t find them now. I may have posted about it and will try to find it
3,051
Here are the pictures of my L185 and how it came apart
See posts #7 and 8
3,051
Here is a view of the rear of the bulb
4,184
Push IN…and twist.
Grady 580
L345DT
Sep 3, 2023
11
NH
I took your advice and ordered the bulbs. Since you advised they weren't very bright, I opted for the LEDs that are supposedly 3x brighter. We'll see. I noticed the keyhole flange around the bulb like the one in your picture. So I guess I should remove the whole assembly of both headlights and then go in from the front? I see that the bulb is bigger but the LED bulb isn't. Maybe it will be clearer after I get the assembly out. Seems like it should be a lot easier to change a headlight bulb. It takes 30 seconds in my car. Thanks for the research. I appreciate it.
3,051
The general steps are:
Remove the assembly from the tractor.
Take the assembly apart and remove the glass lens
Take the bulb out
Replace the bulb
Replace the lens
Reassemble the assembly
Install the assembly back into the tractor.
Getting the assembly apart and then removing the glass lens off were the confusing and difficult parts to me.
Grady 580
L345DT
Sep 3, 2023
11
NH
Take the bulb out
Replace the bulb
Replace the lens
OK, Thanks for the step by step. I'll give it a shot tomorrow.
3,051
Read through the linked post above about how to get the assembly apart. I think there is a clip or something on the back of the assembly that gets a metal ring off of the assembly then the glass lens will come off
Grady 580
L345DT
Sep 3, 2023
11
NH
OK, Thanks. That helps. What were they thinking with this design?
4,184
They were thinking “waterproof, durable, method of illuminating the back of your FEL Bucket”.
Grady 580
L345DT
Sep 3, 2023
11
NH
Funny! I like the waterproof and durable but I might trade a little for ease of replacement if given the choice. I'm hoping the LED bulbs can extend the range out another couple feet.
3,051
What LED bulbs did you get? What type of base are they?
3,051
Please post back then with the results and details of what you bought
