3 point forks
Citro-nut
B4200 Tractor, KH31 excavator
May 30, 2021
50
France
Hi all, I'm looking at getting a set of pallet forks for the rear of my B4200, The ones I have found have a max load of 300kg, they say ideal for "small tractors". However they also say minimum of 30 HP.
Your thoughts please?
BobInSD
L5740
Jun 23, 2020
362
123
South Dakota
I'm not finding the 3 pt lift capacity of your tractor, but that's probably more important than the overall horsepower. You want forks that are beefy enough to lift what you want to lift, keeping in mind that the beefier forks weigh more and that weight needs to be subtracted off of the amount you can lift.
Again, I'm not seeing that number at tractordata.com. Does your manual specify 3 pt capacity?
N3BP
Sep 20, 2016
473
202
Lebanon, PA
Agreed that HP is a useless number to size forks. As stated above, you rear lift capacity is the important number.
I have a set for my small machine and really like them. You might have to add front weight like I do, or you'll be steering with you rear tires, which is always fun.
N3BP
Sep 20, 2016
473
202
Lebanon, PA
Here is a better pic. It's a Northstar 1200 model. 1200LB (544KG) weight rating mounted to my 19hp machine.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
237
85
Jefferson, Ohio
Citro-nut
May 30, 2021
50
France
Hi, that looks quite comfortable on that little tractor, I'll probable go ahead and order some at some point. Thanks.
