L245DT loader hydraulic lines
Throbbin Rods
L245DT
Nov 20, 2015
Lebanon, NH
My l245 DT started leaking hydraulic fluid from one of the steel lines on the loader. It looks like a fitting is turning that shouldn't be. Is there a listing anywhere of part numbers for those steel lines?
Thankyou very much
Bill
5,514
Those lines are long obsolete, you will have to have it repaired if you can't do it.
Find a good welder.
Ktrim
Dec 23, 2020
252
126
Nazareth Pa
Not to step on Wolfmans toes but you should probably have someone braze it for you. Pretty thin to try to weld.
3,654
Thankyou very much
Bill
Got a picture of the line? Usually not hard to make replacements.
5,514
I guess I should have specified, Brazing is fine if done with the right rod, but Tig welding is a much better way to do it. ;)
