Kubota Z781KWI nightmare
brooster
B5200, BX2360, L3940, Z781i KW
May 15, 2021
68
Troy NC
Bought this used a couple months ago with 98 hrs on it. First couple of weeks all is good, but then one day while mowing I cut the blades off and the mower start “missing, surging” it would go from 2300 rpms to 1300 and back up again and again. So I changed the fuel filter and plugs, no change. Then it started doing this also when mowing. So far I have checked fuel tank and pickup, clean. Replaced lift pump, fuel line and filter again. Checked spark with an inline light and it appeared I had a miss in one cylinder, so I replaced that coil pack. This was yesterday, took the mower out and again was missing, but when I started mowing it ran great, 2700 rpms for over an hour and never missed a beat, even when done I cut the blades off and seemed to be running fine. And now today took it out to mow a small patch of grass and it was missing worse than ever, blades off or on! The only thing that I haven’t done yet is checking the valves. Is there something that I’m missing? The engine is a Kawasaki FX850V injected not carburetored
Ktrim
Dec 23, 2020
423
332
Nazareth Pa
Check the wiring on the voltage regulator. Went through similar issue on my zero. Different model. But found wire shorting on regulator causing spitting sputtering misfire.
brooster
May 15, 2021
68
Troy NC
Will do thx
brooster
May 15, 2021
68
Troy NC
Checked out the wires from the voltage regulator and what I could see in the harness and did not see any damage, even moved wires around while running. It was surging the whole time and no change while moving them. I do appreciate the suggestion, thx
Ktrim
Dec 23, 2020
423
332
Nazareth Pa
Welcome. It was worth a shot. It drove me nuts for several weeks. Good luck
4,907
sigh, googled Kawasaki FX850V injected , 1st hit the kawi.eu site info.. NOWHERE does it say it's a gas engine ! ( I was looking for the sparkplug info.....)_
so... did you replace BOTH sparkplugs with whatever kawi says they should be ?
'surging' to mean say 'governor' needs adjustment . maybe the surge spring is missing or broken ??
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
214
376
Moseley, VA
I had it happen on the Kawasaki engine on my zero turn and it turned out to be to of the welch plugs on the carburetor had come out. A few bucks and some nail polish to seal in the replacements and no more issues for the last few hundred hours.
brooster
May 15, 2021
68
Troy NC
Yes, both plugs, twice, adjusted the valves, new fuel filter, new fuel pump, air filters, one ignition coil(waiting on the other), the only other thing I can think of is the voltage regulator, this morning it threw a code of PO563
brooster
May 15, 2021
68
Troy NC
This one is fuel injected
