DT Models
InsideTrader
19
Broken Arrow
Is it possible to have a tractor whose model number ends in DT and it have a Hydro Shuttle? Forgive me if the terminology is a little off. I thought DTs were Sync Shuttle only but I’ve got a guy telling me DTs can be Hydro Shuttle as well.
N3BP
Sep 20, 2016
456
182
Lebanon, PA
DT stands for "Double Traction" or "Dual Traction". It's Kubota's way of saying a 4WD model. So yes, you could have a XXXXXDT (manual, 4WD Machine), XXXXXDT-GST (Glide shift, 4WD Machine), or XXXXXDT-HST (Hydrostatic, 4WD Machine).
InsideTrader
19
Broken Arrow
Thank you sir. I googled that and a website I found said DT meant no cab, 4WD, and sync shuttle. But the guy selling a tractor I’m considering buying tells me it’s a DT hydro shuttle and then showed me where hydro shuttle is written on the side of it. So I was confused. Thank you again.
N3BP
Sep 20, 2016
456
182
Lebanon, PA
Just out of curiosity , what model kubota was it?
mdhughes
L3901DT
Dec 10, 2014
1,244
700
Ste Geneveive county, MO
This is from the Kubota model variants explained page from the main page:
Some general guidelines that hold in most cases:
  • C refers to cab model
  • CS refers to creep speed
  • D or DT refer to four wheel drive
  • E or F refer to two wheel drive
  • HST refers to hydrostatic transmission
  • GST refers to glide shift transmission
  • N refers to narrow tread model (think orchards or vineyards)
5,949
If you give me the serial number, I can tell you if it's a synchro shuttle or a hydro shuttle.
InsideTrader
19
Broken Arrow
I would like to do that. I’d love a data sheet, or something like that, on it. I will not take possession of it until Friday and can get the SN then. However, a couple of hours ago he sent me a picture of the side of the tractor where it said hydraulic shuttle. So assuming he isn’t faking decals or swapped out the side paneling to lie to me, I’m fairly confident it is a hydro.
