I am a new owner of a used B8200. I have been reading online about tires and front to rear gear ratios. I read in the goodyear handbook http://www.goodyear.ca/tires/farm/handbook.html that there should be a positive slippage of up to 5%, that the front tires should lead the rear tires. Mainly that the front tires should slightly pull relative to the rear tires.
Using the tire specs in the manual and calculating the front/rear gear ratio, I determine that the B8200 has a negative slippage. The rear tires are pushing instead of the front tires pulling. Is this correct and proper? My info is below.
I jacked up the right side and rotated the rear tire 20 turns.
The front tire rotated 31.75 turns
Front/Gear ratio = 31.75/20 = 1.588
I happen to have turf tires that match what is specified in the B8200 manual.
Front tire Turf = 24x8.5-12
Rear tire Turf =13.6-16
According to firestoneag the rolling circumference for the 24x8.5-12 is 70 in and the 13.6-16 is 115 in.
http://www.firestoneag.com/compact/tiredetails_pf.asp?ref=1881&artid=359-750&conv=1&subref=168&subid=168
http://www.firestoneag.com/compact/tiredetails_pf.asp?ref=1813&artid=345-210&conv=1&subref=147&subid=147
From what I've read the calculation is:
1.588 x (70/115) = 0.9667
(0.9667-1) x 100 = -3.3%
and supposedly negative bad (the rear tires are pushing).
My question is;
What is going on here? What am I missing in my understanding of this stuff?
Thanks for any input.
My question is;
