Penetrating Oils Info
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
Saw this on another site and thought that some here might be interested.
Penetrating Oils ****
> Machinist's Workshop magazine recently published some information on
> various penetrating oils that I found very interesting. Some of you might
> appreciate this. The magazine reports they tested penetrates for break out
> torque on rusted nuts. ****
> They are below, as forwarded by an ex-student and professional machinist.
> They arranged a subjective test of all the popular penetrates with the
> control being the torque required to remove the nut from a "scientifically
> rusted" environment. ****
> *Penetrating oils ........... Average torque load to loosen* ****
> No Oil used ...................516 pounds ****
> WD-40 ..................... ... 238 pounds ****
> PB Blaster .................... 214 pounds ****
> Liquid Wrench ...............127 pounds ****
> Kano Kroil .................... 106 pounds ****
> *ATF*-Acetone mix........53 pounds* **** (Automatic Transmission Fluid)
> The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission
> fluid and acetone. Note this "home brew" released bolts better than any
> commercial product in this one particular test. ****
> Our local machinist group mixed up a batch and we all now use it with
> equally good results. Note also that "Liquid Wrench" is almost as good as
> "Kroil" for about 20% of the price. ****
> Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can
> also use ATF and lacquer thinner in a 50-50 mix. ****
Ron
3,468
As a retired Toolmaker/Research Technician, that is exactly the ranking order I would have placed them from my experience, but I have never heard of the acetone/ATF mix. I'm impressed! I try to learn something new each day, and this site is very helpful in that respect. Thanks for posting this!
svon89
Westerly RI
I ran into this years ago.
I can vouch for the atf/acetone mix. I use kano kroil. But the atf/acetone is really great. Just remember to mix just what you want to use. The acetone evaporates off quickly.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Fellow OTT member Aquaforce who we've crowned as Captain Candle Wax told us on here a while back that if you heat up a bolt a jam a wax candle on the rusty nut you'll be able to unscrew it by hand.
hodge
Nov 19, 2010
2,960
537
Love, VA
I read this report a number of years ago. I made up some ATF/Acetone, but you had to shake it up all the time because it seperated, and you can't keep it in a plastic container, like a spray bottle. It would leak through the plastic. It worked fine, but it wasn't worth the mess, to me.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
I use PEN-T its Kano Kroil in an airesol can works great, I started use it years ago the power co I work for introduced it to me when having to loosen hardware on power pole next to the ocean. The salt air makes everthing rust within a few miles of the beach.
exkx61
25
Bigfork,Montana
I had same problem also in summer the plastic quart bottle i put mine 50/50 mix got about 50% larger. Put it in metal can and shake before using , not as handy was rattle can with pipe to get into tight locations...its not used as much.
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
The ATF and Acetone are also two primary ingredients in "Ed's Red" mixture used to clean and maintain firearms. If you google it you will find the exact recipe for "Ed's Red".
meinnovations
L3240 BH90
Mar 15, 2025
19
Seattle
Ron
Has anyone seen a comparison with kubota's penetrating oil? My shop swears by it. Comes in a 15oz aerosol can for $11.44+tax. They said they used it and a #4 sledge to pound out my backhoe pins frozen by salty air. I couldn't do it with a 10T porta-power and Acetone/ATF.
