I have lost one of my check chains; actually an enclosed turnbuckle with fittings.
My check chains joined the swivel plate below the PTO, to the lower link inboard of the lifting rods fixing. The measurement is about 8" (200mm) overall ie. from the swivel plate hole to the lower link hole. Can anybody tell me the part number for this linkage? However if the lifting rods should be fixed to the innermost hole of the lower link then maybe I had them fitted incorrectly in which case the check chain assembly would measure about 13.25" overall (340mm) so I would need the part number for that. I attach a picture of the remaining linkage but note the shackle attaching to the swivel plate is not very clear but just showing above the PTO shroud.
Help appreciated as finding the right parts in the UK is not so easy.
Thanks in advance, Nick
