M9000 clicks won’t turn over
Joe Hollas
m9000
Sep 10, 2014
Cameron,TX
If your M9000 only clicks, won’t turn over,this is the problem. Starter relay located at front of tractor on the left. After bypassing both safety circuits and replacing all the relays under the dash, this was it. It would be nice if the parts manual listed ALL the relays in 1 section. Spent 700$ on relays and fuel solenoid before I got to this. Hope this helps someone.
3,316
6,369
The WSM point to exactly what really you would have needed to work with.
2,547
Too bad SidecarFlip wasn't here.....
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
The shotgun repair process does work, it just gets expensive as you have proven again. Hopefully next time you get a WSM or find someone that can diagnose it for you. Also you now have reinforced the blue car system(the last blue car didn't start due to a bad relay so this car is also blue so I better replace that relay).
