Throttle control lever
Alb$$
Bx2370
Aug 11, 2023
Middleburgh NY
My BX2370 throttle control lever(increases/decreases engine RPM snapped off after about 100 hrs. Dealer said the part is discontinued and is looking around if another parts place has one. So far no luck…. Has anyone had a similar problem and have found a fix? Appreciate anyone’s advice
JasonW
625
388
Al
Kubota #K2581-45126 LEVER, ACCELERAT
I found this for $18 on Messicks(kubota dealer). If that’s the actual part you need.
lynnmor
B2601-1
May 3, 2021
1,736
1,539
Red Lion
Is this what you want?
10,233
3,916
I think you should NAME the incompetent and unhelpful Dealer.
Alb$$
Bx2370
Aug 11, 2023
Middleburgh NY
Thanks to everyone for replying. Messicks has it in stock and it’s been ordered. PS the parts guy never called back Sharon Springs NY Kubota. The lever was getting very stiff to operate, but never expected it to break off especially since only has 100 hrs of use.
3,406
1,855
When the throttle lever gets hard to move or too loose to stay where you set it, there is a friction adjustment on the bottom that needs to be adjusted.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
354
141
St. Louis, mo.
When it comes to parts and diagrams, you can always count on Wolfman. 😎
garrett47
Kubota BX2370, 2016/17
Dec 29, 2024
Temple NH
Thanks to all who responded, this also broke off on my tractor with less than 100 hours and in looking around, this is a common problem. The metal itself split above where it is attached and seems like poor metal quality, but thankfully the rest of the tractor seems to be doing ok.
