BendPak lift setup
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
382
537
SE, NM
So like I said in the other thread I was disappointed with the lift being made in China. However after a good inspection this this thing does look pretty good. All the welds are very consistent with no splatter. Can't see penetration but oh well. All the parts, pulleys, cables, hoses etc look well made. A couple of pics from the first day. IMG_2419.jpg 71183404892__EBB8EC0D-4161-4770-8028-28716A2816DE.jpg
6869704x4
Jun 29, 2011
382
537
SE, NM
I didn't have high hopes of that fifty year old concrete meeting specs and it failed, just barely. Also have no idea of the psi or if any rebar. So, I have two options. Increase the size of the base plate to spread out the load? Big unknown there, or do this.
I have the XPR10. New slab requirements will add about $800. Wife will not be happy.
6,889
So how did it fail - minimum thickness? I am sure the published requirements have a significant safety margin built in.
5,066
Nice hoist. Having one is a must for me. Working on the ground and getting my fat a$$ up and down is a disaster.
How many pounds is it rated for? I now see it's the xpr10
Mine is a 10K and called for a 4" minimum at X psi (I cant remember)
When i drilled the mounting holes and had an "average of 3 3/4" depth.
No problems or cracks in the concrete for 10 years, and I quite regularly put my 3/4 ton, extended cab, diesel up.
5,066
I forgot to add.
It also said that "no more than 3/8' of shims could be used.
But I had one side just north of that, so I used a "bedding compound" like they use for setting large factory machines in place. I also use to use it when an airplanes needed to be "fixture'd" in place for large structural repairs.
After it was shimmed and torqued, I basically I made a "wall" about 1" around the base with aluminum tape. Then poured the bedding grout in and it fills in all the gaps underneath the base.
I'm sure someone here knows the name of the stuff, I can't recall it right now.
10,617
I did 6" at 7500psi, on the garage slab.
I don't think I'll ever put a lift in there, but I can drive / lift / move just about anything on it.
5,123
Wolf man that just how I wanted to do mine, I was out of town for work and they said it would be like 3 weeks before they could do the pour,, cool,, the contractor came and poured the week I left never put in the tubing electrical nothing drains nuttin. They subbed it out, and the company they subbed to went tits up before I could get a claim filed, seems they were already out of business when they did mine. Ya gota watch contractors!
6869704x4
Jun 29, 2011
382
537
SE, NM
Yeah, minimum thickness. The safety factor is one of the unknowns.
5,066
Wow, thats cool as hell.
KKBL
Jan 5, 2022
129
142
Girard, PA
When we installed a 9000 lb Rotary symmetrical two post, the 4 inch 5000 psi was probably "good enough", but went a bit over-kill to make it "WAY more than enough".
Cut out two 4 ft squares, removed over 12 inches of soil, used two layers of mesh, #6 bars, L-Bolts for the lift posts and 5000 psi concrete. Have a friend that installs foundations for things like roller coasters, so the only cost was for the 1 3/4 cu yard of concrete delivered.
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
I did similar. Cut out 3 ft squares, dug down and out. Re-poured with 6,000 lb mix with rebar so the new part is 10" deep and extends about 6 inches under the existing slab in all directions. Did it myself so the only expense was for the bags of concrete, a days rental on a mixer, and a few Aleve. I'll post pics if I can find them.
6,889
Pretty much what the installation instructions for my 9K lift said to do. They also said just tie the new section to the old slab with rebar.
