I found this forum tonight and this was the first thread I read. Sorry for the poster’s dilemma. Over the years, I have drilled out a number of freeze plugs, and so far have had good luck.
There are some interesting suggestions so far
If this were my problem, I think I would start by measuring the distance from the hole, up to the head gasket surface. This would be to see if the hole was far enough up the bore to be a problem with the ring sealing. One would need to know the stroke of the engine to know how far down the bore the piston travels.
It is possible that the drill went through the piston as well as the block. Turning the engine a few degrees and probing the hole again could check this. If the wire now strikes the side of the piston, instead of the cylinder’s far wall, this would be the case. This wouldn’t be a big deal, if there is a hole in the lower part of the piston skirt. If the hole were in the ring land area, the piston would need to be replaced.
Another thing to check would be to remove the injector and shine a bright light source down the hole. Turn the engine so that the piston is at bottom dead center and look for the light at the hole.
If the light only shone out the hole with the piston in the bottom third of the stroke, the hole could be plugged and possibly work just fine.
I have used JB weld for a number of engine related repairs, including cracked heads. It is some amazing stuff. Again, if this was my repair, and the hole was low in the bore, I would dab on the JB weld and see what happens. If the hole were farther up the bore, I would remove the head and pan, and take out the piston. Press in a metal plug, trim it off flush with the bore, hone the cylinder and put it back together.
