M5950
5,175
Won't start, new battery, checked clutch safety switch, no start
Remove and thoroughly clean ALL battery cable ends ( 4 connection points ).
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
While cleaning cable connectors and battery terminals inspect connection to cable. If corroded it may need replaced. Do not overlook the frame ground connection point. After replacing connectors on battery terminals tighten securely. If you can move them they're not tight.
8,841
Clarify:
No start is: It's cranking (engine turning) yet won't fire.
No Crank is: Starter does not engage or will not turn motor.
