L2501 HYDRAULIC ARM FIX
j77mzx
Kubota L2501
Feb 6, 2022
Upstate NY
Hello all, I don't post much on here unless I really need help but this time I'd like to offer a solution for a problem I encountered and I believe it's happened to more than just me. I have an offset ditch and Bank flail mower that I use behind my 2022 l2501. When you use it in the offset position it is offset to the right side of the tractor. It is most convenient in this position as you don't have to turn all the way around to keep an eye on your mower and you're not driving over what you're trying to mow. The problem that I ran into is somehow it puts enough force on the top left hydraulic arm of the 3-point setup to mangle the little bracket that holds it on and pushes the arm off. I don't claim to be a physicist or a professor in geometry, quite frankly I'm not sure how it's possible as the stabilizer arms were tighter than a duck's ass, all I know is that it happened after only about 30 or 35 hours of mowing this year. This is the only implement that I use that is offset in any way and it's the one I was using when it happened. Luckily I was able to finish the mowing job and get the machine to the truck. I do have the KTAC insurance and my dealer told me that they would repair it no problem, free of charge, minus the $250 deductible. My issue being that after I paid $250 to them I was still going to have the same factory set up that was eventually going to break again. So here was my solution. I bought another bracket off messick's for $20, got two slightly longer M8 x 1.25 by 20 mm 10.9 grade bolts from tractor supply. I then used my plasma cutter to cut a piece of quarter inch plate into a round using a WD-40 can as my template. I put the piece of round plate on behind the new bracket and tightened everything up. This should prevent whatever pressure is on that arm from being able to push it off again. My only concern would be what's going to break next. If there's enough Force there that it's shoving that arm off than something is going to give somewhere and I doubt it will be the quarter inch piece of plate. I hope I'm wrong but if it ever happens I'll be sure to report back. I've only just finished this project I will report back when I've got several hours of use on it but I believe this could help some folks who have run into this issue. I've got about 2 hours and $30 into the repair and I believe it to be much stronger than the factory setup. Happy tractoring!
-Justin
5,187
-Justin
"what's going to break next"?:(
The 3pt lift arm?
Let's hope not!
5,269
Nice job on the plate cut out and nice fix, but I'm thinking like Fried1765. Where is the stress being transferred to?
I've never used a mower like that so I'm having a difficult time in figuring out how it "pushed" that plate and bent it.
I suppose having KTAC back you if it turns catastrophic makes it more palatable though.
5,515
2,226
That arm is not designed for any side load. Vertical load only. Something has had to pull it to the side in order to mangle that part like that. You'd be wise to figure out how before something else breaks. Keep us updated if you don't mind.
3,656
2,075
You are correct, it has happened to others and has been posted on this site.
Mostly, people scoffed and claimed it could not happen or there is another problem. I have encountered it a few times in the past, mostly using three-point mounted discs and pushing with a back blade.
Kubota's suggestion was to make a heaver plate for the LH end of the rock shaft, the same as you have done.
Blue76
L2501 / L3600 / Yanmar YM2500 / Various implements
May 30, 2025
38
12
-Justin
Curious, What size / model flail mower do you have?
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
Paragraphs are important.
Or at least helpful.
Just developed an app that let's me condense really long paragraphs into a couple of lines.
I've always struggled with being able to express myself in fewer words and hence had to find something that would help me So I booted up my PC and got to coding until I finally did it! I successfully created an app that reads through all my typed and creates the most optimal sentence to summarize everything I've typed.
Long story short...I don't think it works.
