Tractor runs but not great. I’ve replaced the lifter pump put new filter housing on. Drained cleaned the tank several new fuel lines. Currently when I run I have the tank off so I can crack the injectors it looks like I’m getting air still. I don’t have a way to test pressure to the injectors but when I shoot the exhaust with infrared the front cylinder is 300 the rest are around 200 indicating the front one is firing. Is this just a bleed it more issue? My old does was that way. Or is the injector pump bad. Or are the injectors plugged or bad? Also. Before took tank off and did all this. If I ran it wide open for 4-5 minutes it would eventually almost stop running. Indicating it’s running out of fuel.
Any help is appreciated thanks in advance!!
