B2601 Front Snowblower Hydraulics...
jkrubi12
Sep 24, 2012
403
302
right coast
I am contemplating acquisition of a front BX2822A snowblower for my B2601 ('22) and would like to configure an attachment for connecting the blower hydraulic system to the Swift-Tach receptacle located on the tractor after loader removal. In other words, I'd like to adapt a Swift-Tach 4-hose inline adapter to the blower so it will smoothly attach hydraulically (plan to use electrical deflector). This project may involve 4 new hoses along with a new Swift-Tach 'half'; could even require fabrication of hose supports, etc.
It's my understanding that the BX2822A blower hydraulics perform up-down of the box, and swiveling of the discharge chute.
Has anyone attempted such a hydraulic adaptation? (K-Connect & driveshaft frame needed of course)
I'll understand if users of the Swift-Tach connector had seen issues; I personally have not; I'm evaluating the theoretical usage of the connector to mate to the blower system. Thanks in advance for ideas or suggestions :)
cthomas
LX2610 HSDC
Jan 1, 2017
858
569
La Farge Wi
Some members have a post with all the part numbers to just install the pioneer couplers, I would go this route as the snowblower goes on and stays on until winter is over. It is only four couplers and not worth the risk with the Swift-tach setup. If you want to go the Swift-Tach I am sure some members will dig in their trash can and sell you that one. I believe this is the part you are looking for https://www.messicks.com/part/7J066...t=Kubota #-,7J066-85020,-COUPLER(QUICK MOBILE and is only about $700 plus shipping. For that amount of money you could install a hydraulic chute deflector if you already have the third fucntion.
cthomas
LX2610 HSDC
Jan 1, 2017
858
569
La Farge Wi
jkrubi12
Sep 24, 2012
403
302
right coast
Actually, reading the above-mentioned thread ...'worst Kubota parts ever'... was what got me thinking of adapting the blower to the Swift-Tach coupler initially.
I think it's a valid, doable adaptation. Hose supports are the most questionable aspect at this juncture.
6,932
Should be just about trivial. How else;would you accommodate loader and blower? Just remember your loader valve likely has regen on the bucket spool and that won't play nice with a hydraulic motor.
cthomas
LX2610 HSDC
Jan 1, 2017
858
569
La Farge Wi
But th
My loader joystick that goes up and down controls the lift cylinder of the snowblower. Can't remember what the dump function does(I think chute rotates faster). I do miss using the third function(chute deflection) and chute rotation to blast mice while snow blowing. I have never tried to blast the farm cats either while snowblowing.
