The glo plug light on my ZL1-235 dash never goes out and 12v goes to the plugs constantly. They are all burnt out because of this so I want to fix the problem before I replace them.
I thought maybe it was controlled by the engine temp but I have fixed all the cooling problems on my ZL1-235 and now the temp gauge works and everything seems good but the glo plug light is still on and they are still getting voltage so that wasn't the cure.
I have a wiring diagram but it's all in Japanese so I can't really tell what controls the plugs getting power. There is no special glo plug spot on the ignition switch, only off/on/(start? as the writing is in Japanese on the spring return part of the switch). Without cutting all the wiring looms apart I can't follow where the glo plug power wire is coming from so what I was thinking I would do is place a momentary push button switch and a relay to control power getting to the plugs and just use that. Is that OK to do as a fix?
I've never had a diesel before so how long would I need to push the button for before starting the engine in cold weather? It starts easily now when it's warm out. The previous owner heated the intake manifold with a torch but that is a pita and I want to do it using the plugs.
