I bought an engine block heater that mounts into a freeze plug hole. Someone told me that to get the freeze plug out, I should drill a small hole through the plug and put a screw into the hole to have something to pull on. Well, I did way too good a job drilling the hole. When I got the plug out, I saw that I had drilled the hole right through the engine block. (It was a lot easier drilling than I would have ever imagined.) How big a repair am I looking at? Would the hole be into a cylinder? If it is, would it be above or below the piston? Can I plug the hole with something like JB Weld, or can I get a sleeve put in the cylinder, or is the block ruined? Any help?
