Good afternoon. I am new to this site and would very much appreciate help/advice with the following issue: I recently inherited a 3 cylinder diesel Kubota GR2110-54 lawn and garden tractor with 502 hrs on the hour meter. The tractor was very well maintained by the previous owner performing all of the hourly maintenance required by Kubota. I used the lawn tractor for about 20 hrs to date. Yesterday, after mowing for about an hour, I noticed that the coolant temperature light was very “dimly” lit. I had no issues with lawn tractor while mowing. Because of the bright sunshine, it was very difficult to even see that the light was “dimly” lit. The engine coolant was full, fan belt tight, radiator free of grass clippings/debris, air filter new, no leaks or steam. I shut the engine off and let it cool down over night. The next morning, I started the engine and let it run. When I turned the key to the “accessory” position, the oil pressure light and the electrical charge light came on and were “bright white” in color. The coolant temperature light was off. After about a minute of running, the temperature light came on very slowly and stayed “amber” in color (like a light on dimmer switch at its lowest setting). See attached photos:
The first photo is the coolant temperature light after the engine was running for about a minute. The light never got brighter the longer the engine ran
The second photo is the coolant temperature light (left) not on and the oil pressure light (right) “bright white“ when the ignition is in the “accessory” position.
I Is the engine actually overheating? Any thoughts as to why the coolant temperature light is coming on after only a minute?
I am going to purchase an infrared thermometer gun to get an idea of the engine temperature. I would appreciate any advice on the cause and how to fix.
Thank you.
Thank you.
