Land Pride joystick switch for 3rd function (pn 833-739C)
the4hornes
L2501 hst
Feb 21, 2022
NC
Just thought I'd pass along some info on the button on a Land Pride 3rd function joystick knob. One of my switches was not working sometimes and the red button had popped off. I'd have to fiddle with it to get it to work. My Kubota dealer wanted $40+ for the switch (pn 833-739C). I found that the same switch can be purchased from a electronics store for a lot less money. I ended getting my switch from Mouser.com (part number P9-411221) for $12.62. The Land Pride switch has Otto 21649 printed on the bottom of it. The switch that I ordered from Mouser has the same 21649 printed on the bottom of it. Just google Otto P9-411221 to see some online suppliers or go to a local electronics store and order that Otto part number. I installed mine today and it is the exact original Land Pride part(except the terminals that the wires solder to were slightly shorter). You will have to solder the wires to the new switch.
Reactions: 7 users
5,164
If we could only find the source for the handle itself. Does anyone have any idea where it comes from? I can't believe that they are having it molded themselves.
5,187
View attachment 107647 View attachment 107648
The oft mentioned 3rd function electric switch questions are rather confusing to me.
I have a 2006 Kubota 3rd function system, but there is no switch on my 3rd function control lever.
GrizBota
Apr 26, 2023
1,147
733
Oregon
IMG_1279.jpeg Good find. Nice job. Appreciate the info just in case.
Something I’ve noticed, the LP 3rd function kits a person can buy on line do not have the stick mounted on/off switch for the solenoid power. Anyone know where a person can get that switch?
I’ve installed my own switch and it’s in a fine place, but it seems like LP cheaps out on the kits. Heck, so charge another 20 or 40 bucks, it’s not like they aren’t already charging about a grand for the kit anyhow. And if a person was price sensitive, they’d buy a different manufacturers kit, not like there isn’t a handful to select from that are hundreds of dollars less expensive.
The switch circled in blue from the photo @meatlOverpizzia shared recently when a goat buggered up his dad’s third function lever (thanks).
the4hornes
L2501 hst
Feb 21, 2022
NC
Here is a pic that shows how to determine the part number for Otto push button switches like the one pictured in my previous post for the Land Pride 3rd function.
5,301
Thanks for posting this.
I don't need it yet, but definitely something to keep in mind.
the4hornes
L2501 hst
Feb 21, 2022
NC
View attachment 107678 Good find. Nice job. Appreciate the info just in case.
If you haven't done so already, I'd suggest looking on the underside of the switch (between the terminals) to see if there is a Otto part number. I would guess it is a Otto manufactured switch just like the "open/close" switches were on my LP joystick. Search for that part number on Mouser Electronics website. Let me know if I can be any help.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
401
66
Wa
I had the red button pop off, saw it by the cab door and figured I had time to get it later.
Well, I guess there is enough movement in the door while running the snowblower to allow it to fall out of the cab.
I just ordered 2 of these switches and hope they work like the OP's did.
6,285
The original switch looks like has .110QC terminals, the replacement has solder tabs.
so... P9-411221 would become P9-431221.. the '3' is the terminal style, no soldering required.
The 'fun' is seeing if they have stock of it. Maybe not in the 'red' button,but in the 'white' button.
Also other distributors, say Digikey, may have the exact switch though.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
I use https://www.trustedparts.com/en to search the main electrical component distributors for electrical components. It makes it quick to search for variations across multiple sources at the same time.
jt040900
L3901 4 WD
Feb 10, 2020
34
Bishopville
Thanks same problem here cap never came off just intermittent. Ordered two that was very helpful info thanks again!
NewL3302FL
L3302, loader, grapple, 60" brush cutter
Aug 14, 2023
North Florida, US
The control handle is p/n: 380-368s (Land Pride). I've been chasing down issues with mine - the close function is burning through switches regularly, and while I found a short in the hot wire (unprotected wire against machined, unfinished metal on a tractor - what could go wrong Land Pride?), now that I've fixed that I think it might be something in the spool because it's still killing switches, assumedly from overdrawing current.
Apparently the part number for the 3rd fxn. assembly is either 380-362A (-363A for FF couplers) or 380-366M - I can't really see a difference except that maybe "M" is a master part number for the entire kit regardless of couplers/solenoids, then the couplers/solenoids determine the "A" part number.
Anyway I had some difficulty finding those p/ns (my dealer didn't freakin know), but once I got them, I could find basically every piece on the parts diagrams. Main power switch is 843-178C (I replaced that with a cheap Amazon 12mm switch with a rubber grommet to make up the dead space - works great and watertight), and everything else you can find on Messicks or wherever.
Hope that helps.
Larry Sacks
L3901
Jul 15, 2026
Western KY
Thank you so much for posting this. It was a very easy fix. Just be very careful when soldering to not to touch the wires insulation and if you do like I did shrink tubing works great for this. Don’t ask how I know this… source for button. https://www.mouser.com/en/ProductDe...mtrr1ItrBrw==&countryCode=US&currencyCode=USD
