Good afternoon; I'm just following up on the oil leak in the hydraulic assist steering.
I removed the hyd. assist and sent into my local Kubota dealer for repair They where able to secure all the leaks and replaced the rod end as in the pictures attached.
When I removed the parts, I cleaned up the parts behind and found that the hydraulic pipe that returns to the cooler was quite worn. This can be seen in the photos attached. As you turn the tractor, the hydraulic assist unit move back and forth and also rotates slightly. This movement has worn the hydraulic pipe by about 3"
If you look at the photo, you can see the return line is held into place by a strap that is welded to the pipe and it also holds the pipe away from the frame by about 3/8" The 3/8" space lines the pipe up directly with the inlet of the cooler. I am assuming this has been like this from day one. I have been told that the B7200 does not come with power steering and this had to be an add on..
So I'm wondering if any body else has come across this and might have a solution. Thankfully right now there is no leak from the pipe. I can only think it must be paper thin at this time.
Don
