Hello all,
About a year ago, I bought an old Kubota M4500. Didn't take long to figure out it has overheating issues.
I was suspecting it was the head gasket, so this spring I pulled the head, had it resurfaced, and replaced the head gasket. I found 4 of the injectors were not sealing well, so I had them rebuilt. I also flushed the radiator, and checked the water pump. But it still overheats.
Any thoughts on what would be causing it to overheat? I was thinking the injection timing could be out, but I don't have a timing light setup for a Diesel. Also not sure how it would have got out considering it is set by shims.
Any thoughts on things to check are appreciated! Thanks in advance.
Grant
Grant
