B7100 front axle oil question
AOW162435
B7100
Jun 16, 2023
106
51
Ellicott City, MD
I drained & refilled the front axle today: 3/4qt in the differential housing, and about 5oz in each gear housing.
Afterwards I realized the housing bolted to the axle also has drain & fill plugs. Is that its own chamber? Or does it share oil with the differential housing?
Andreas
N3BP
Sep 20, 2016
473
202
Lebanon, PA
That's the front driveshaft U-joint housing. The drain is for water condensation. I'm pretty sure that bolt should be facing down. I think your housing needs rotated CCW by one boltset. Neither of my B7200's have that condensate drain, so Kubota must have determined it unnecessary.
2,636
I have been told that very early B7100s had "open" cup bearings in the u-joint between the driveshaft & differential. They ran in an oil bath within that housing for lubrication. The housing was filled with oil until it ran out the fill plug. That style u-joint was soon replaced with a modern, grease-able joint, eliminating the need for the oil bath.
If the housing is rotated to place the plug on the bottom, it will no longer line up with the driveshaft.
N3BP
Sep 20, 2016
473
202
Lebanon, PA
Thanks for the education Bill. I sold my B7100 years ago and didn't remember changing any oil in that housing. I did manage to find an old picture of mine and sure enough it did have a fill and drain plug...
AOW162435
B7100
Jun 16, 2023
106
51
Ellicott City, MD
Yes, the plug shown in my pic is the higher of the two.
I assume when I remove the drain plug, whatever comes out is from this chamber only?
Andreas
2,636
Andreas
Theoretically, yes.
But I know when I rebuilt my front axle, I put that housing together dry, but some time later, I checked & there was some oil in there. I think some oil migrated from the differential after some STEEP uphill work I had done.
AOW162435
B7100
Jun 16, 2023
106
51
Ellicott City, MD
Theoretically, yes.
Thank you. You reassembled it without oil because you installed the new-style u-joint?
Andreas
2,636
It already had it in, probably from the factory.
I have never seen one of the old style, and don't know of anyone who has, but an old, grizzled Kubota tech told me that was the reason for that housing/fill plug/drain plug.
Mine is a 1979, sold in 1980.
According to
https://www.tractordata.com/farm-tractors/001/2/7/1271-kubota-b7100.html
they started making B7100s in 1976.
I have the feeling the old style u-joint was phased out pretty early.
AOW162435
B7100
Jun 16, 2023
106
51
Ellicott City, MD
According to
Excellent, thank you. My serial number is from 1979, so I guess my options are to simply drain & refill, or slide the rubber boot up to see which u-joint version I have.
Andreas
