Tractor will not turn over and none of the lights illuminate. Ive been through most of the obvious things to me....lever positions, fuses, battery, chewed wires etc. The first thing I found was a 30 amp fuse that had blown. I replaced the fuse but nothing happened. I've tested from the negative terminal to the terminal with the starter wire on the solenoid with a DC meter. I get full power from the battery to the solenoid terminal. I also ran a wire from the positive side of the battery to the smaller post on the solenoid where the ignition wire connects (nothing happened when I did that? Is that the issue?) I tried jumping the tractor across the solenoid terminals and all I get is a whirring sound? I suspect this could be a problem, but want to make sure that something else like a bad switch may be the culprit. Not sure if this works or not but I did test the ignition plug with a voltmeter, reading jumped around in the range of around .015 to .025 volts. So what I'd like to know is there something I have not checked? Is the solenoid test conclusive and is it a solenoid issue? Is the ignition switch bad? This is my 4th Kubota 4wd tractor so I am very familiar with them...simply have not encountered this failure mode before. Thanks in advance.
