BX tie rod Zerk fittings
TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Jun 25, 2022
160
72
Upstate New York
Has anyone installed zerk fittings in the tie rods ends on a BX tractor? My new BX has sealed tie rod ends. I'm thinking about drilling them and installing self tapping Zerk fittings. Drives me crazy I can't grease them and using a needle does not seam to be as good as a grease fitting.
Has anyone done this ?
4,492
I am sure there are more constructive things to worry about.
4,816
I have never worn out a tie rod on any of the 2 BX tractors that I owned. I have had a few torn factory boots that I had to replace.
xrocketengineer
Nov 14, 2020
749
647
Merritt Island, Florida
If you want to feel paranoid about something on your tractor, next time you remove your MMM, make sure to check the CV joint boots on the propeller shaft connecting the engine to the HST. o_O
TheMurf
Jun 25, 2022
160
72
Upstate New York
As a matter of fact, I had the deck off yesterday, cleaning, grease and sharping the blades . I checked all the rubber boots etc. Spray all the linkages with fluid film and clean under the machine. Everything looks good but it should since the machine has only thirty hours on it. I'm a fanatic about maintenance I guess. Bugs me as to why there are not more zerk fittings on the BX. My thirty year old Gravely professional rider has them all over. I would think Kubota should have more than they do..
TheMurf
Jun 25, 2022
160
72
Upstate New York
I remember doing CV boots on Cadillac Eldorados back in the 70's in my dads service station. Still got the special tools in my tool box for that job.
Smokeydog
Jun 2, 2020
669
623
knoxville, Tennessee
Factory joints don’t seem to have much lubricant. Use a needle to pack the joints lasts a long time. Have seen a fellow install some zerks on some replacement joints. Have to take the joint apart. Replacement joints on larger tractors are expensive.
TheMurf
Jun 25, 2022
160
72
Upstate New York
Smokeydog, Thanks.Maybe aftermarket joints gave them ?
2,965
My BX2200 is approaching 20 years old now with 1500+/- hours on the clock. Like DustyRusty, no worries about tie rod ends yet.
I would worry more about the plastic HST cooling fan, if I wanted to worry about something. 🙂
4,816
Yeh, I replaced the cooling fan after about 10 years of it having one broken fin. It wasn't a difficult task, but it was time-consuming, especially since the tractor had a Curtis soft cab that had to be removed before the floor pan could be removed for access to the fan. If the fan on my BX23S with cab ever needs to be replaced, I will replace the tractor before I would attempt to do that repair.
TheMurf
Jun 25, 2022
160
72
Upstate New York
You would think Kubota would use a aluminum fan instead of that plastic one.
4,816
They could also use a fan made of nylon plastics that can take a shock loading and not crumble. Today there are plastics that perform better than metal in many applications. The only reason they don't is because of the bean counters. The same goes for the quality of the boots on the drive shaft and the tie rod ends.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
930
1,198
Pittsburgh
Sounds like a good application for a 3D printer.
BAP
Dec 31, 2012
2,751
867
Almost no tie rods in any applications, wether it be tractors, cars, or trucks have grease fittings. Just like most drive shafts on vehicles wether it’s for the front or back don’t have grease fittings.
Smokeydog
Jun 2, 2020
669
623
Driveline shop you can get either sealed or zerk fitted parts. Sealed will last longer if your not friends with the grease gun. Greaseable can last several times longer.
