Anyone order an overhaul kit from eBay shipped from China are they worth using or substandard have an older b7100 thinking of trying one tractor doesn’t get used a lot but want it to go when needed don’t want to do this twice thanks everyone
^^^^^Anyone order an overhaul kit from eBay shipped from China are they worth using or substandard have an older b7100 thinking of trying one tractor doesn’t get used a lot but want it to go when needed don’t want to do this twice thanks everyone
Presumably the engine.....but the OP didn't specify.Overhaul "what" exactly?
(and no, only as a last resort would I, regardless of your answer)
Correct, items from China 'can' be very well made (depending on manufacturer specifications).Not ALL things 'made in China' are 'substandard'. helped a neighbour pull 350 out of his El Camino 5 years ago. It hung on the engine puller for TWO years,never dropped an inch,heck it didn't move. So SOME things are built GREAT !
Also the carbs on their 9HP Honda knockoff engine fit real Hondas 100% and run first pull ! $22 Chinese carb replaced $250 Honda carb, zero issues.
It just means that a turd really can be polished. Carbs aren't complicated and can be made out of cheap pot metal. I'd rather my wrist pins and cylinder liners to at least have some sort of quality control.Not ALL things 'made in China' are 'substandard'. helped a neighbour pull 350 out of his El Camino 5 years ago. It hung on the engine puller for TWO years,never dropped an inch,heck it didn't move. So SOME things are built GREAT !
My dad taught me that there are two ways to do things:Anyone order an overhaul kit from eBay shipped from China are they worth using or substandard have an older b7100 thinking of trying one tractor doesn’t get used a lot but want it to go when needed don’t want to do this twice thanks everyone
Yes engine but aren’t the engines made there to begin withOverhaul "what" exactly?
"Anyone order an overhaul kit from eBay shipped from China are they worth using or substandard have an older b7100 thinking of trying one tractor doesn’t get used a lot but want it to go when needed don’t want to do this twice thanks everyone"
No.Yes engine but aren’t the engines made there to begin with
I would consider buying a Chinese carburetor that could be easily changed if there was a problem, but not an overhaul kit that would result in another overhaul being required if something failed.Correct, items from China 'can' be very well made (depending on manufacturer specifications).
But many, many items are not. Hence the reputation for 'Chinese Junk' that exists in not a few markets.
"Substandard" would be a most charitable term.
External Chinesium parts are worth the risk.I would consider buying a Chinese carburetor that could be easily changed if there was a problem, but not an overhaul kit that would result in another overhaul being required if something failed.
