Overheats only when turned off
england006
b7500
Jun 11, 2021
11
ohio
B7500 operates at mid temp fine but reservoir drain boils all water out when engine is off. Changed thermostat and radiator cap but same problem. Engine oil stays same so assuming no head gasket issue. Radiator internals looks clean and not plugged up. New temp sensor confirms operating temp seems ok.
This is a real headscratcher. Any ideas?
Nicksacco
Sep 15, 2021
764
502
Bahama, NC
Just to be clear:
1) Engine runs ok and normal temps according to gauges
2) turn off engine and let it sit
3) radiator overflow tank becomes empty - coolant expelled from the overflow tank onto the ground
Is that correct?
jaxs
B1750HST
Jun 22, 2023
1,046
794
My knee jerk is to think gauge might not read sensor and engine is actually overeating while running. Before digging into engine I'd use a temporary heat gauge to confirm normal temperature while running. I've seen engines that burped some coolant on shutdown but unless already boiling while running I've never seen the system loose most of coolant. FYI blown head gasket doesn't always crossover between oil and coolant,blown gaskets often allow exhaust gas to enter cooling system to cause overheating. Auto parts store sells coolant dye that changes color in presence of exhaust gas.
england006
b7500
Jun 11, 2021
11
ohio
I thought the temp sensor was bad too. Thats why I replaced the original one on the block but ended up getting the exact same normal reading. No other visible leaks of coolant anywhere on the motor.
england006
b7500
Jun 11, 2021
11
ohio
Just to be clear:
Is that correct?
thats pretty much what Im seeing. The overflow reservoir hose has steam come out until all the coolant leaves the system including the radiator. I can continue to refill daily but want to fix whats going on.
lmichael
Kubota G2160
Apr 23, 2021
838
433
Rockford IL area
Maybe start with a pressure test, and then possibly run the exhaust gas test. At least these give you baselines
2,990
You can get reasonable inexpensive infrared thermometers and see what temperature the radiator is getting to during running and then sitting.
3,581
2,011
After working it, do you let the engine idle for a few minutes to let it cool down before you shut it off??
jaxs
B1750HST
Jun 22, 2023
1,046
794
I suggested GAUGE might not be reading sensor. I'm aware the sensor has been replaced but new sensors don't fix defective gauges.
L35
Jun 13, 2010
700
818
CT
Are you using properly mixed radiator fluid? Circulating “water” as you call it won’t boil as easy as heat soaked standing still water like when you shut the tractor off..
england006
b7500
Jun 11, 2021
11
ohio
I do a 50/50 mix of coolant and water.
