MX 5400 DTC Clutch
reedysprings
MC 5400DTC
Jul 7, 2023
TN
I have a new MX5400 with manual transmission and 91 hours. The tractor is at the dealer because on two occasions after mowing a field with a flail mower for 2-3 hours the clutch will not release when the pedal is pressed down. Meaning I went to come to a stop to grab some water and pushing in the clutch does nothing the tractor keeps going forward with no noticeable difference. I mow at 2300 rpm (indicated PTO on rpm gauge) in low 4th gear. I let the tractor sit overnight and the clutch engages and works like it should. The dealer replaced the clutch cable as it appeared to be stretched and the cable cover was separated from the metal crimp at the adjustment threads. Again after mowing two hours clutch was doing the same thing. The dealer has my tractor and states they drove it for 30 mins at 2000rpm with pto engaged and cant replicate the issue. I provided them with a video of what the tractor was doing to include the rpms and temp gauge all within norms. The steering has also blown the right side hydraulic steering line twice in last 10 hours. I don't know if this coincidental or a symptom of the clutch issue such as metal in the lines or over pressure etc. The dealer just called and basically asked if I wanted them to continue to troubleshoot it. Anybody have any thoughts? Im getting the impression they aren’t interested in trying to fix it or open it up to see if they can find whats wrong.
**update they cant replicate the clutch problem with 1/2hour of testing. They replaced the steering hydraulic lines with 3kpsi steel braided versus nylon lines. I am waiting to hear what their plan is moving forward. No call back again today.**
7,437
If it's under warrantee, tell them need need to make it right!
If it's not then it's your call on how much you want to get into it for.
I would be focusing on system pressures.
reedysprings
MC 5400DTC
Jul 7, 2023
TN
Thank you..I definitely told them to fix it since its under warranty..just looking for some possibilities of cause as they seem to be less than enthusiastic in trying to fix it.
7,437
My Number 1 focus would be system pressures, aka the regulator valve and relief valve
reedysprings
MC 5400DTC
Jul 7, 2023
TN
I have a rod that goes from the clutch bar that the clutch cable is attached to. This rod runs to the rear transaxle. Do you know what it is called? I cant find it on the diagrams and I am wondering if it somehow connects to the pto clutch and is preventing the clutch bar from moving due to an issue with the hydraulic pto clutch.
