Kubota l6060 3rd function to grapple help
PaulL
2,678
1,671
NZ
I'd guess one had gunk or flow restriction. Swapping lines shouldn't fix it per se, but taking apart and putting back together might.
OldSchool59
L6060 HSTC, Rhino Ag TW36 , American Ag 72” land plane,
Jan 15, 2023
68
20
Happy its fixed but still confused. You swapped what lines?
Do you really mean loader valve or more likely third function valve?
If third function was it work port lines to cylinder or pump supply and return?
This isnt adding up for me and I hate mysteries.
Lol Dan- it will be OK buddy 🙂 . So I’ve probably not explained it correctly - follow the lines from the quick connects at the front of the loader , back to the connections by the cab ( where you disconnect the 4 quick connects for the loader it’s self and then there are 2 more for the 3rd function. I disconnected the 2 for the 3rd function and swapped them - then the grapple started working , crushing , gobbling up everything I grabbed with it and then opening quickly to dump said pile of brush and heavy branches. Does this help? I think that they just plumbed the two lines in reverse but I’m a big dummy so what do I know lol!
6,326
Possible but I'd say unlikely . The tractor is only 5 months old and should be clean as a whistle. I am wondering what else was touched in the process of swapping those hoses. Something electrical perhaps.....
OldSchool59
Jan 15, 2023
68
20
Well Men, with a shortage of mechanics at our local bota dealer I don’t want to take it in there to possible sit for a month or two! It is under warranty and will be for 4.5 more years. If the valving is bad , it will show it’s ugly face so I will have to cross that bridge when I come to it! I had a bota service manager contact me yesterday evening and he figured the 3rd function valving was probably bad or had a sticky spot but sometimes swapping the lines does the trick. 🤷🏼‍♂️
6,326
I thoght we covered those couplers early on.
GrizBota
Apr 26, 2023
1,147
732
Oregon
The fix confuses me as well. Somehow the hoses being switched probably wasn’t the initial issue. Otherwise the grapple would have worked, just “backwards” regarding which momentary on switch caused the grapple to open (or close).
What really confuses me is why Kubota put the 3rd function valve where they did. Very exposed. As are all the FEL lines being connected outside of the FEL frame rails. Must have saved a couple bucks in manufacturing. I’m thinking a newbie in the woods could get expensive.
OldSchool59
Jan 15, 2023
68
20
I don’t understand this either!
I built a shroud around minebut I do agree. Easier access vs open to easy damages!
