Got me a new to me BX2200 and all four of the deck wheels are froze. I've soaked them in PB blaster let them soak for a while and such three times. I just need to go a notch lower Any tips?
Yep I know they shouldn't touch the ground all the time but I'm scalping big time. I think the book says no more than .5 in. I just got the deck level for my 2.5 cutting height. That 60 in deck was a mother to level. Lol. I wish I had a 54.Try heating the deck housing with a torch (NOT the pin that the wheel is attached to, which has the positioning holes in it), and see if they free up when it expands?
Of course that will burn the paint off...
On my BX2200 when set up properly, at the number 4 setting, I think I have 2 and a half holes showing. Looks to me like you might have to go more than just one hole. When I set my deck height up according to the manual, I rarely scalp anymore. For 16 years I was scalping area regularly. Of course, I never wore out my wheels, since they rarely did anything...LOL
I got one pin that's is bent already. Going to be a pia to get that out lol.Tappy tap the shaft and the housing with a hammer, keep soaking with KROIL, remove the pins and mow with it to jar things around, try to twist the wheel from side to side, anything that will cause the smallest movement. Don't wail the pizz out of it with the hammer. I've un-stuck old farm equipment from the 1930's using this method. PATIENCE IS THE KEY.
Yep! My great uncle used to sell them long time ago. Unfortunately simplicity doesn't seem that good like they used to. I might rig up something similar to a simplicity roller.Yeah, I am not a fan of the decks. I really wish they had a deck like Simplicity does. They never scalp
Got me a new to me BX2200 and all four of the deck wheels are froze. I've soaked them in PB blaster let them soak for a while and such three times. I just need to go a notch lower Any tips? View attachment 106405
I got two of them that way! The one I cut both ends off and going to try tap them outI got one pin that's is bent already. Going to be a pia to get that out lol.
