How strong is the front axle? GF1800
DennisY
GF1800
Jul 2, 2023
iowa
I would like to put a loader on the front of a GF1800. I know this is a judgement question with no great answer. I have looked at some snow blowers that are pretty big and far out ahead of tractor. Looks like quite a load on front axle. If I had a loader bucket as close to tractor as I can make it, would I be safe at say 300 pounds in bucket? The loader itself would weigh a few hundred pounds. What have others seen for attachments on that size of tractor? If I were to break front axle, that would be a lot of days rental of a skid loader.
10,055
How the heck are you going to attach a loader to a GF1800???
6,032
EASY, just takes a LOT of cash, ton of steel, two boxes of hydraulic things and presto......a month later, version 2.0 will kinda work... :giggle:
Yes, it can be done ...be an 'interesting' project...could drain a small wallet though.
DennisY
GF1800
Jul 2, 2023
iowa
This one seemed to lose roll bar before we got it. The 4 bolts behind and under seat is the main attachment point where the roll bar mounted and where the rear weight bolts on is the other. I have already done the months work on it over the last couple years. I haven't bought anything, just stuff in shop. Now I get close to done and get cold feet about breaking something. It is my wife's mower. I should know I can't build anything little and light.
10,055
Looking over the blueprints for it, the ROPS mounting points are no where near strong enough to support a loader.
When a B of the same vintage is fitted with a loader it requires a subframe to stiffen and strengthen the mounting points.
If you don't add a proper subframe you'll just break the tractor in half.
You're asking a lot of a purpose built mower that was never designed to have a loader attached to it.
And to answer your original question how strong is the front axle, well it's not a heavy or strong as a tractor that was designed for the operations with heavier loads.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Surely you jest.
6,032
curious.. went back to my files... and the Sears ST16 had a loader(self levelling ! ) would lift over 400#.
....so that 'mower' could be modified, big wheels up front is a bonus and has a full frame.
as for capacity.. start with tire weight limit and work backwards. can it be done, yes. should lift 500# providing you can design the hydraulics. Also have to add weight in the back as a counter balance.
Try Googling 'ST16 loader'..should find the OEM manual for the loader.
when I made a 'clone' for a JD317 I had, I started with wood to get the dimensions right THEN cut up steel.
10,055
No offence, but your comparing a cast iron beast with a aluminum unit, not anywhere in the same wheel house!
6,032
since K tosses a big mower up front, I'd assume the front axle( really a 'rear' up front ) and the frame could support a loader setup. hmm, wonder what the tires are rated for ?
I know front axles on ST16 are just 1" shafts.
one of those 'have to see it, to design' projects.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Sounds interesting.
Try not to break the mower. Maybe pick up a cheap used riding mower just in case. And maybe a spare axle.
Steamer Pete
LX2610
Mar 29, 2021
49
42
Holland, MI
Just wondering how stout the transmission is? Loaders on these compact tractors are supposed to be run in low gear to be able to push into a pile of dirt. Too high of a range, and you'll stall the tractor before your bucket is any where near full.
10,055
This would be all good and fine if it was a tractor, it's not it's a lawn mower, not built the same.
See the picture I posted.
10,055
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Im sad to be late to this one!
Firstly I’ll refer you to this thread which will very likely make your day: Same thing on a Toro
Next, i’ll say that it’s a less scary thought than you might assume durability wise, because a front mount mower is basicaly built like a backwards tractor. Thats good in the sense that unlike a ‘regular’ tractor the loader weight is mostly carried by the stronger axle and not the weaker one! I personally wouldnt be too concerned about axle durability. The downside is that unlike a ‘regular’ tractor you cant easily add the required counterweight by hanging something on the 3pt hitch, because you dont have one.
I think the idea of a loader on that type of machine is tenable but will take a lot of effort to be ‘as good’ as a garden tractor with a loader (comparable size class) mostly because it’ll require a more complicated design both in terms of mounting the loader, and in terms of adding the required counterweight without ruining the steering effort.
I would be excited if you decided to take it on. The result would be a pretty cool machine as long as it could lift at least 3-400lb and not be a pita/deathtrap to operate. I once mounted a 500lb crane to the front of a converted riding mower and that presented all kinds of issues which i mostly worked out and ended up with a cool little machine that i was glad i built. I havent touched it in a long time but im still so affectionate towards that project that i keep it around for an eventual ‘round 2’. So i doubt you’ll regret it either way.
DennisY
GF1800
Jul 2, 2023
iowa
That was some interesting reading and links to other posts. Thanks
