Loader sensitivity
paul888
US
I was testing different tractor at my dealership last week and I noticed that the loaders were extremely sensitive which made for very choppy loader movements. Is there a way to adjust the sensitivity or is this something that will resolve itself with seat time?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
Seat time. I too was very choppy at first. Then I started to get a feel for the stick. It doesn't take much pressure to drop the bucket when there is a load. Now, I'm getting to the point where I can back up, curl, and lower the bucket while looking backwards. You'll just get a feel for how much pressure equals how fast it moves.
lynnmor
B2601-1
May 3, 2021
1,591
1,354
Red Lion
I replaced the worn hydraulic pump, on a self-contained loader, with a pump that has a higher capacity since the original is no longer available. Now you need the finesse of a watchmaker to operate smoothly. So I too would like to make it less sensitive and wonder if a hydraulic control/throttle valve would make sense.
5,725
If you think bucket operations are 'sensitive' wait until you use pallet forks !!! After 5 years, 1000+ hrs and I'm almost, kinda getting the hang of using them with. They're far different to operate than my forklift. I suspect it's a compromise on spool valve geometry, pressures,cylinder selection and other things.
As ET says, seat time, will really,really help
3,716
+1 on seat time.
One thing I do to help with the learning curve when its practicable, is to run things at idle rpms.
5,175
100%
Also, it's not helpful that the engines in the newer models need to be run faster because of the DPF, etc.
Another great reason for buying a used tractor that precedes DPF.
Grandad4
Apr 5, 2016
387
133
Greensboro, NC
In addition to what others have said, loaders on larger tractors often have better spool setups than the smaller models of the same brand. Likewise, you should expect the top brands to have more refined controls.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,244
159
Coyote Flats,Texas
Yrs ago I added an adjustable flow control valve to boom circuit on loader on my Kubota M4900. The flow control valve eased operation while handling 4X5+ rd bales that weighed 900-1000#s
