Bad seal on brush hog gearbox?
IronRyan
Kubota 3560
Apr 1, 2023
46
25
Tennessee
MY bush hog sat for several years. When i got back into it, I cleaned it up and changed the gear oil out of the gearbox, but now this is happening. Is this a bad seal? How do i go about repairing it?
5,725
yes, bad seal...
basic repair process....
order seal and case gasket
drain oil..
remove Ujoint
clean shaft real good(fine sandpaper)
to me it looks 'rusty/rough',bits got into seal,
remove 4-5-6(?) bolts
slide housing forward ,off shaft
clean shaft again, be sure it's smoother than a baby's butt !!!
pop out seal, install new one
reinstall housing
refill oil
overall not a bad job, you'll spend 1/2 time 'polishing' the shaft to be 100% sure it's smoooooooth !
Norman
LX2610HSD;LA535;LP 60" grapple; WC68 chipper; GB60 SW cutter
Sep 30, 2021
84
97
Georgia, USA
Looks like it is a bad seal. There are some good youtube videos out there that show how to replace seals on brush cutter gear boxes I would search out there. I've seen two methods, one is where you remove the upper gear from the housing (those bolts on the vertical surface) which gives you access to the seal (in some cases). The second is using a metal screw tapping into the seal itself from the outside and then using a claw hammer or pliers to pull the seal out using the screw. On my gear box I used the first method and it worked fine for me.
6,698
Buy a tube of corn head grease (at your local John Deere dealer) and use the whole tube.
N3BP
Sep 20, 2016
486
213
Lebanon, PA
Check the input shaft for excessive play. That will cause a seal to fail as well.
IronRyan
Kubota 3560
Apr 1, 2023
46
25
Tennessee
yes, bad seal...
drain oil..
remove Ujoint
reinstall housing
refill oil
Thanks alot!
3,716
For folks like me, who know very little about tractors, the obvious question is.........What does that do?
5,725
Maybe it's to replace the proper oil and it's soooo thick ,it'll never ooze out the damaged seal ??
If so, it's a backyard bodge NOT the correct way to FIX the problem...
William1
BX25D
Jul 28, 2015
1,223
423
Richmond, Virginia
Before I 'fix' anything like this, are you sure you have the right amount of oil in it? Was it empty when you tried to drain it? Is there a plug on the side to set the oil level'?
My point being if over filled, it will leak due to expansion. There has to be air space above the oil bath.
6,932
Before I 'fix' anything like this, are you sure you have the right amount of oil in it? Was it empty when you tried to drain it? Is there a pug on the side to set the oil level'?
Good point. Looks like some space in that gear box is taken up by water, which is not uncommon.
IronRyan
Kubota 3560
Apr 1, 2023
46
25
Tennessee
It's possible. I don't think so, but i do remember something funny happening when i filled it, but i can't remember exactly what happenend.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,244
159
Coyote Flats,Texas
Back yard or front yard repair I've had cornhead grease in my JD 709 rotary mower that has a faulty blade shaft seal for several years. While operating cutter cornhead greases liquifies some & when machine sits it solidifies. Cornhead grease has been used for over 40 yrs so it has it's value.
Flintknapper
L2350DT
May 3, 2022
1,944
2,466
Deep East Texas
Yep.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
547
310
Mandeville Louisiana
As others have said clean it really well and polish the seal area with Crocus cloth, use a double lip seal, if it's available in that size. If the shaft has fretting use a Speedi-sleeve. Ensure the gear box vent functions.
3,716
I have never heard of a Speedi-sleeve.
Thanks for posting that, it may come in handy some day!
Yep.
I was going to say, Interesting "get around", especially if your ever in a pinch.
But apparently it works very well. (y)
Flintknapper
L2350DT
May 3, 2022
1,944
2,466
Deep East Texas
If the input seal is leaking.....then the output shaft (underneath the deck) probably is too. The output shaft seal is hidden by the 'stump jumper' (if the cutter is so equipped) so you can't see it to verify.....but it is probably leaking also.
It is MUCH harder to get to.....so some folks look for an alternative. Corn Head grease is a semi-liquid grease and can be a good answer for those not equipped to perform the proper repair (or just don't want to).
It isn't necessarily a 'band-aid' fix, JD uses the grease for lubrication in some of their brand new implements with gears sets.
hedgerow
377
350
Malcolm NE
I have a fifteen foot flex wing mower that came from the factory with corn head picker grease in all the gear boxes. I don't have a gear box on the farm that doesn't have corn head picker grease in it. Always make sure you don't have any moisture in your gear boxes and that the vents aren't plugged up. I have seen many of gear boxes leak because of a plugged vent.
