B 7001 tires size
Pierrecnwl
Kubota b7001
May 26, 2023
Quebec
i bought a B 7001 with a b7100 hood, the seller put new tire on the tractor, the one in the back are 8-16 as it is suppose too, in the front they installed 6-12 nhs,my tractor is a 4dw, I don,t want to break anything of course, 5.00-12 and 5-12 seems like they have the same outside diameter, can someone guide me?
There is site says 8-16 rear and 5-12 front and other says 8.00-16 and 5.00-12
Thanks for your help
3,020
1st - lets establish something, do you own a B7001 OR a B7100 that has a serial number that starts with B7001.
Since you have the "hood" markings as B7100 - chances ARE it is a B7100 and not a B7001
Many early models of this tractor were REALLY B7100's , BUT the serial number started with B7001.
Is your machine a geared tractor? I am going to assume it is a B7100D ( And it has a 4 bolt pattern front rim?)
As for the tire sizes - for AG based tires, you should have this :
IF a true 7001:
IF a true 7100
Both tires are the same - other than the width of the tire = the 6-12 is just a little wider than the 5.00-12.
HTH
torch
Jun 10, 2016
2,870
1,112
Muskoka, Ont.
1. If you are calling it a B7001 with a B7100 hood just because the serial number starts "B7001", be advised that is normal for an older B7100, it doesn't mean the hood has been changed.
2. Tire size depends on tire and rim type. Agricultural tires with a traditional "tractor tire" tread use different rims than turf fires.
Ag tires are specified by the rim size."6- 12" refers to a rim 6" wide and 12" diameter. They do not give any indication of the actual diameter of the tire itself.
Turf tires are specified by the tire dimensions, including the maximum diameter of the tire.
By the sounds of your description, I assume you have agricultural tires and rims?
3. Neither rim diameter nor tire diameter are the deciding factor for the 4wd ratio. What really matters is the "rolling circumference" of the tire, which takes into account how much the tire squishes under the tractor's weight. That's a number that manufacturers are reluctant to provide (probably because of the variability). The best way to verify it, since you have the wheels installed already, is to mark the tire and ground were they contact, move the tractor exactly one revolution, and measure the distance between the two contact points. Repeat for the other axle.
Now you can calculate the ratio, and compare to the spec for the tractor. If they are within a few percent of each other, you are good to go.
Edit: B7100 4wd ratio = 1.464:1
Pierrecnwl
Kubota b7001
May 26, 2023
Quebec
