Larger tires on lx2610
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
I have a 2021 lx2610su with 25x8.5TracLoaders on front and 15x19.5 on rear. I am looking at getting a new 2610with a cab. Can not find this tire option on lx2610 cab model. Appears it is not an option because of front pto. Appears mmm will not fit with larger tire and mmm will be too high with larger tire. I like the lx261su I have and just wanting same tractor with a cab.I would not use the mmm. I like the stance of the larger tire. If I purchase a lx2610 can I install the size tire I have on the su model on the regular lx2610?
6,389
The tire size has nothing to do with the Mid PTO or MMM as they offer that tire on the LX2610HSD.
I'm betting the tires will either not clear the cab or it puts the center of gravity too high.
LFP57
LX2610 Land pride QH 10, BB1560, EA 55" Wicked Grapple, Top n Tilt, Wicked T
Sep 21, 2021
108
38
I ordered my LX2610 open station with the larger R14s, yes, with these larger tires, you can't use the mid-mount-mower. I didn't care because I don't use it anyway. With the larger ties, there's about a 15 pound per tire increase in weight and they'll hold a little more liquid ballast as well.
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Thanks. I like the larger tires. Ordered them when I bought my lx2610su. I do not need a mid mount mower either. the Lx2610su is the perfect tractor for my use. Just wanting a cab. Per local dealer tire size I want is not available on cab tractor. Thinking about owing to tire dealer to see if they can install if I buy cab tractor with smaller tires.
S-G-R
LX3310
Jun 17, 2020
1,119
2,267
PEI Canada
I have the larger tires on my LX3310. I'm pleased with both the traction and ground clearance. Here are the part numbers off my quote.
(2) ABR 8646 25x8.50x15 R14 SR
(2) ABR 8645 15-19.50 R14 SR
will721
LX2610, Ford 2n, Ferguson TO20
Jun 6, 2023
179
186
Quad Cities Area
I did a ton of research on my lx2610 and the differences between its sub models, the l series and the b series.
From my understanding the larger tires fit all 3 sub models of the tractor. However, the mid mount pto attachments are aligned around the smaller tires. So you wouldn't be able to use a mmm. However I'm not sure why they don't list it as an option for the cab version, I do believe it was listed for both the lx2610hsd and su. I'd chat up the dealer to see if they would be willing to do it anyway, I can't imagine there would be a clearence issue with the cab, although if there was you could probably solve it with wheel spacers.
I only went small tire because the wife insisted we may want a mmm in the future. Which at the cost of a new zero turn these days if mine were to quit I could be convinced of a mmm instead.
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Thanks
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Thanks. I appreciate the information.
