jkrubi12
Diesel Exhaust Fluid (DEF) does not have anything to do with a Diesel Particulate Filter (DPF).
I believe that most (if not all) Kubota diesel's that have a DPF do not have or use DEF. I'm pretty sure that the only Kubota's that have a DPF are those that are sold in the USA with engines rated for more than 26 HP.
A DPF is generally the first 'filter' encountered in the exhaust system after the exhaust gasses leave the engine and enter the exhaust system. It's purpose is to collect unburned 'particulates' from the exhaust and 'reburn' them to clean the exhaust output. When a diesel engine equipped with a DPF enters a 'regeneration' phase (a 'regen') the Engine Control Unit (ECU) will force the engine to run at a determined RPM, usually a mid-to-high RPM, in order to heat up the filtering screen in the DPF and burn off the accumulated particulates and 'clean out' the DPF. This process is accomplished through high heat, time, and in some systems, the injection of raw fuel into the DPF.
DEF is used in conjunction with a specially designed catalytic converter to convert Nitrous Oxide (NOX) into water and nitrogen before the exhaust output leaves the exhaust system. This is accomplished by injecting DEF (65% urea / 35% water) into the catalytic converter which (in conjunction with the exhaust-heated catalyst) converts the NOX into water and nitrogen. This NOX catalytic converter is generally the last component in the exhaust system prior to the gasses exiting the system.
Both the DPF and the NOX catalyst usually have sensors attached to them which monitor the exhaust flow or content to ensure proper functioning of the component. In the case of the DPF the sensor's purpose is to monitor exhaust flow and determine when there is a flow restriction, indicating a build-up of particulates on the filtering screen inside the DPF. In this case the ECU would (or should) initiate a 'regen' to burn off the accumulated particulates. I would be interested to hear from Kubota tractor owners / users whose machines are equipped with manual regeneration switches and who have performed manually-initiated regenerations what actually occurs during a manually-initiated regeneration.
Additionally, the notification of a DPF problem could indicate the failure of a DPF sensor, in which case a repair would be considerably less expensive than a DPF replacement, possibly even user repairable.
